PWM on Gigabyte Mobo
CaptainFreezy
Hello all,
I'm looking to quieten down my system and was looking at some PWM fans. Was wondering if my Gigabyte Z97X-Gaming 3 motherboard can control the PWM fans via the systems headers. If so, would I get to that via system viewer, or some other way? If not, I presume the best way forward would be to get the Sentry 3 sold by PCS and use that instead?
Cheers,
steaky360
It appears as though the 3off system fans on the motherboard are 4pin fans so should be PWM - you could always get the fans and plug them into the motherboard - if the mobo can't/wont operate the fans properly you can look at getting a fan controller after that?
