garamo
Here is the spec:
P5K SE
8800GTS
4GB Ram
I got this machine back in 07 and the PSU has now given up! I haven't fit a PSU since I was at college and I know a lot has changed since then but I'm confident I can change it easily enough. Was just wondering if this - would be compatible with the above spec and if it would be a reliable choice. I need something that wont break the bank but I want the thing to work! I tried looking at an older PSU I had but it didn't have a connection for the 8800GTS.
It's probably worth mentioning that the GPU wouldn't get a heavy load from gaming as I have a newer system for that (which I purchased from PCS of course!).
P5K SE
8800GTS
4GB Ram
