PSU Name
gavcor
Hi Guys
Im ordering the 450w quiet 80 PSU. Does anyone know the actual name for this PSU as i dont seem to be able to locate a spec for it.
mantadog
Superhero Level Poster
It probably changes all the time, hence its not named like the corsair ones. Someone from PCS might be able to tell you what they are using at the moment. I can tell you i also have the 450 w psu and it is labeled "fsp group inc" but i don't know if you will get the same one.
gavcor
Hi mantadog
Thats spot on mate just checked mine and they are currently using FSP ones.
