Programs for cpu temperature monitor.
Buzz
Master
I use AI Suite myself which is always different then other progs also.
You could try Real Temp which I found also good
Real Temp
AI Suite II gives the Tcase temp, which is basically the temp of the CPU's heat spreader. This temp will be lower than the individual core temps.
I would go by RealTemp's numbers, as they are read from the digital sensors built into each individual CPU core
tom_gr7
Life Serving
personally i only like asus probe II, and cpuID, the others often come crammed crap in the installations.
try cpu_z never tried it myself, but gpu_z is really good, and light too
Keedar
Expert
Thank You Tom.
You said gpu-z?This is not for graphic card only? For card i have msi afterburner witch is good i think :) I will try asus probe II.Thanks again.
tom_gr7
Life Serving
Thank You Tom.
i think there's a cpu z, as well as gpu z.
Do you have msi gpu's? mine are palit and come with "vtune" you can monitor the temps and increase the gpu fan speed, great for playing really heavy games like shogun 2 n bf3, but gpu fans can be noisy,
