Problem with Google Map and Firefox ONLY when using GeForce GTX 670M
hargil
Problem with Google Map and Firefox ONLY when using GeForce GTX 670M The integrated graphics works ok
When I have the laptop configured to use the internal graphics card all is well
But if I configure it to use the GeForce GTX 670M
Then when Google Maps fires up I initially see the map but then a few seconds afterwards a white 'box' covers the screen.
All other web sites work fine, just Google maps has the issue
It did work fine until a few months back…
internet Explorer works fine with both graphics configuration.
If I start FireFox in safe mode (no add-ons) it is fine.
so I disabled all the add-ons manually and found that it was still a problem, I could not disable the Kaspersky Internet Suit add-ons, they kept re-enabling themselves!!!
it appears that Kaspersky Internet Suit is the issue but it would let me disable the KIS add-ons.
Does anyone have any thoughts?
GeForce GTX 670M
FireFox 37.0.1
Internet Explorer 11.0.18 64 bit
Vortex III
windows 7 64 bit
i7-3740QM @ 2.70 GHz
16 GByte RAM
