Problem connecting dash cam to pc
Ok so I've recently purchased a nextbase 522GW dash cam to go in the new motor, and have downloaded and installed the player software from nextbase, which installed on the Berserker fine, however when I follow the Ibstock to connect the camera to the pc, the camera connects and then drops out as per this video
If I follow the exact same procedure with the laptop everything works fine
For those not familiar with the Berserker here's the spec
The Berserker
CORSAIR iCUE 465X RGB GAMING CASE
Corsair H100i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
EDUP PCIE WiFi 6 Network Card AX1800Mbps Bluetooth 5.2 Heat Sink 802.11AX 2.4Ghz/5Ghz Wireless PCIe Network Wi-Fi 6 Card PCI Express WiFi Adapters 6dBi Dual Band Antenna for Windows 10/11 64-bit
NO OPERATING SYSTEM REQUIRED W11
Edition Windows 11 Home
Version 23H2
Installed on ‎12/‎10/‎2023
OS build 22631.2792
Experience Windows Feature Experience Pack 1000.22681.1000.0
NO RECOVERY MEDIA REQUIRED
Firefox™
Standard Build - Approximately 16 to 19 working days
Promotional Item
Get Resident Evil Village with select Samsung SSDs
Welcome Book
Logo Branding
PCSpecialist Logo
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/4qrnAtmtdb/
I’ve got the older 512GW, and found it picky with the choice of cable (would only works with the provided cable). But if that same cable is working on the laptop then it should be fine in the PC.
Provided cable is very short, I've ordered a couple of cables from amazon, due to arrive later today, so will see what happens with them
