Power Supply advice conflict
Just noticed (when I changed my RTX3080 pre-order to the 6800XT pre-order) that the system recommended I downgrade from my 750W PSU a 650W one as I'm only using 588W.
Now, I ignored this as it gives me a bit of headroom if I want to add/upgrade to more power-hungry components.
However, on the order page it advises I upgrade to an 850W PSU as I'm using 768W?
scarpa1
There are a few other 850w PSU's in the configurator now, AX version and the ASUS one which is in stock. I think the AX Corsair one had new stock delayed so some should arrive soon.
Both are a bit more expensive than the RMx version though.
