I'm sure everyone has read of the SSLv3 POODLE vulnerability. I'm a Firefox user and Mozilla have promised to disable SSLv3 in the next Firefox update, but that's not until mid-November. So I've been looking for the about:config hack to turn it off now and I've just found it.
If you want to disable SSLv3 on Firefox now type about:config in the URL bar and click the "I'll be careful" message box.
Search for security.tls.version.min and double click it. Change the value from 0 to 1 to force TLS as the minimum. To test your browser visit https://zmap.io/sslv3/, they will tell you whether your browser now supports SSLv3 (site requires Javascript).
I don't run Chrome but I understand that adding --ssl-version-min=tls1 to the end of the shortcut target field will enforce TLS in Chrome. Note: there must be a space between the existing program name and this text, and there is a space between the tls and the 1.
Apologies if this is common knowledge, I didn't know it until this morning. POODLE is a minor risk for most of us but it's worth disabling SSLv3 I think.
