Please View
walkington
what you think to this? £1159 budget is £1200 including monitor specifically one chosen
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
ASUS® P8Z68-V: USB 3.0, SATA 6GBs, NVIDIA®SLI™, ATI®CrossFireX
1.25GB NVIDIA GEFORCE GTX 570 - 2 DVI, HDMI, DP - 3D Vision Ready
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£72)
Monitor
IIYAMA E2473HDS 24" LED WIDESCREEN, 2 x HDMI/DVI-D HD 1920x1080 (£169)
MadMan
Super Star
Looks spot on mate. If you plan on adding a second gpu later on then a bigger psu is required.
Fear
You have not listed it on the spec so not sure if you selected the silver warranty or not but make sure you do as it is only £5 and it extends the collect and return from 1 month to a full year just incase you should have any problems, and your spec above looks good.
