slimbob
I wonder if someone can offer me some helpful advice. I am looking to buy a new monitor for my desk so I can move my existing monitor down on the floor. Years of manual labour and landscaping have taken their toll on my back and I spend a lot of time on my P.C on my bed now as sitting unfortunately aggravates my back when it flares up.
My old PCS PC is:
Intel Core i5 Quad core i5 -4670 CPU (4 Cores) @ 3.40GHz 6MB
(Intel HD Graphics 4600)
No dedicated GPU
ASUS Z87-K: ATX, USB 2.0, USB 3.0, SATA 6GB/S, XFIRE
WD 500GB Velociraptor SATA 111 6GBs, 64MB cache (10,000 rpm) WD5000HHTZ
8GB Kingston Hyper-X Genesis dual – DDR3 1600MHz X.M.P (2x4GBKIT)
Windows 10 Home 64-bit
My requirements are really basic. I just use Word, YouTube, Watching online video/movies and general online stuff. No powerful video editing software, no powerful photo editing software and no hi-tech gaming.
The only other use is playing my old favourite SNES games on the BSNES emulator. As I don’t have a dedicated GPU and instead use integrated graphics, I don’t have FreeSync or G-Sync capability. Therefore, on my emulator settings I select “Dynamic Rate Control” not “Adaptive Sync” and make sure my monitor refresh rate is set to 60Hz for NTSC games and 50hz for Pal games. Works like a treat!
So, from my understanding and searching on line for my needs:
I don’t need anything above 60hz fresh rate
I don’t need anything above 1080P.
I don’t need speakers built into the new monitor although often they come that way anyway.
I don’t need FreeSync or G-Sync.
I don’t have display port on my P.C so will be connecting with HDMI.
My questions and considerations.
1 – 21.5 or 24” screen?
My current monitor is 21.5” and I sit 34 inches away with no problems. I have never used a 24” monitor before but I could go for one but may have to move it a bit further back like to 36 inches as a big screen can give me headaches (using friends in past). But my understanding is generally the smaller screens normally have higher PPI so not sure what is best a 21.5” a bit closer to me or a 24” a bit further away? Anyway, taking into consideration my requirements do you have any experience or advice?
2 – Response time?
My understanding is 1-5ms is really important for serious gamers playing current games on great systems. As I am only playing SNES games using an emulator on my old P.C is it really an issue for me? My current monitor is 5ms (TN) panel. Some of the monitors that I am considering are 5ms or some are a bit higher like 7–9 ms. Is it an issue or am I best sticking to 5ms max?
3 – Panel type?
I am also not 100% sure about whether an IPS or VA is best for my usage. My understanding is that TN are good for gaming and allow high fresh rates so doesn’t seem applicable for me and my requirements. Would you recommend a IPS or VA? I am edging to IPS?
4 – Good Brands and suggestions
I hear the follow brands often getting praise:
Dell
ASUS
BenQ
LG
Acer
AOC
After a lot of time hunting around the below monitors seem quite a good match for my requirements to my untrained eye. However I am not sure if the more expensive ones are too good for my 10 year old P.C and wasted on it. I have included Argos clearance bargains at the end in case those are more suitable and more compatible with my P.C
21-22” Picks
BenQ GW2283 - £129 – 22 inch actual 21.5”, IPS, 60hz, PPI 102, 2xhdmi 1.4, 5ms, headphone jack, built in speaker, audio in,
https://www.benq.eu/en-uk/monitor/home-office/gw2283.html
Dell SE2222H - £119 – 21.5”, VA, 60hz, 1 x hdmi 1.4, 8-12ms, 6985 4.5 stars, PPI 102
https://www.dell.com/en-uk/shop/del...onitors-monitor-accessories#techspecs_section
AOC E2270SWHN - £104 – 22” (21.5”), TN, 60hz, 1x HDMI 1.4, 5ms, Headphone out.
https://eu.aoc.com/en/products/monitors/e2270swhn
Cheaper Argos Clearance Option
https://www.argos.co.uk/product/9395950?clickPR=plp:63:89
Samsung S22A310 22”, VA, 60HZ, 9ms, 1 HDMI 1.4, no speakers, no audio in, £65,
24” Picks
BenQ GW2480 - £144 24” actual 23.6”, IPS, 60hz, built in speakers, headphone jack, audio in, 5ms, ppi 93, 1xhdmi 1.4, Built in speakers,
https://www.benq.eu/en-uk/monitor/home-office/gw2480.html
AOC M2470SWH - £125 – 24” (23.6”), MVA, 60HZ, 5ms, Speakers, 2x HDMI 1.4, headphone out, 7240 4.5 star https://eu.aoc.com/en/products/monitors/m2470swh
Cheaper Argos Clearance Options
https://www.argos.co.uk/product/9421082?clickPR=plp:49:89
MSI Pro MP241 23.8 Inch 60Hz IPS FHD = £85
7ms, 1xhdmi, 92ppi.no speakers
https://www.argos.co.uk/product/8173616?clickPR=plp:72:89
HP V24i, 23.8” IPS, 60Hz, no speakers, 1x HDMI 1.4, £102
I can't thank you enough for any help, advice and feedback you can pass my way and if there are any other picks I have missed and overlooked.
Cheers.
Bob
My old PCS PC is:
No dedicated GPU
2 – Response time?
3 – Panel type?
Dell
ASUS
BenQ
LG
Acer
AOC
21-22” Picks
24” Picks
Cheers.
Bob
