KaseyRaccoon
Hello !
I am stuck on an issue that has left my PC unusable.
It is stuck in an infinite boot loop now for months - which is honestly quite awful and annoying now. This happend once before around 3 years ago, after an update, and after 2 days of being left to do it's thing, it was fine up until January of 2025.
I have updated all drivers, it is updated to Windows 11 and ive attempted any further updates in the sporadic moments that it works again.
Any updates or changes, no matter how small, send it into a reboot loop for days until it turns itself off and then resumes the loop when turned back on.
I've reverted back to previous dates in system restore and even wiped my PC and done a clean install, but it still happens. I want you to understand i haven't changed anything either, this just happend. And keeps happening.
I've had people tell me my BIOs is outdated aswell as some drivers but this is the issue, as mentioned, any changes cause this to happen, even a windows update or a prompt to restart to install a program so I can't alter anything anymore at the risk of this being stuck in a loop... nothing is working.
Please can you advise me or help me with where to go or what to do next? This PC is very important to me and being unable to use it is causing alot of issues and definitely making my life a little more difficult.
I really appreciate any help you can give me.
NZXT H511 MID-TOWER GAMING CASE (
AMD Ryzen 5 3600XT Six Core CPU (3.8GHz/35MB CACHE/AM4)
GIGABYTE B450 AORUS ELITE: DDR4, USB 3.1 - ARGB Ready
512GB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
CORSAIR 650W CV SERIES™ CV-650 POWER SUPPLY
PCS FrostFlow 120 Series RGB High Performance Liquid Cooler
3 x PCS ARGB LED Fan + Controller Kit
Windows 11 Home 64 Bit
Monitor
IIYAMA E2283HS-B3 21.5" Widescreen Monitor x 2
(This is what I ordered and nothing has been changed yet, although I am eyeing a new GPU if my PC ever works again).
Kind Regards KaseyRaccoon.
Monitor
