Please advise me on my build
Rubyjuno
PCSPECIALIST.CO.UK SPECIFICATION
The specification below has been formatted so you can easily copy and paste this to our forums when discussing your specification. Once you've copied the specification, please click here to continue.
FRACTAL FOCUS G BLACK GAMING CASE (Window)
Intel® Core™ i5 14-Core Processor i5-13600K (3.5GHz) 24MB Cache
PCS FrostFlow 200 Series High Performance CPU Cooler
Windows 10 Professional 64 Bit - inc Single License
Price: £1,813.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/F3EQmSGHEa/
Hello all, although I've been building PCs for many years (my first PC was over 30 years ago and had a 40MHz CPU, 4Mb RAM, a 105Mb HD and a 1Mb GPU!), I haven't done one for several years so I've lost touch with recent technology.
1. My budget is up to £2000 max.
2. You may laugh, but I mostly play older games (Panzer Corps, AoE2 DE, C&C remastered) but I do occasionally play a "more modern" FPS such as Battlefield 1, Metro 2033 Redux. I want to keep my options open for future games (although my best years on FPS games are behind me), hence the higher spec than required. I do a lot of other stuff on my PC, but nothing demanding. I also want to keep the PC I get for many years.
3. My monitor is an Iiyama ProLite XUB2390HS, 1080p @ 60Hz and I'm very happy with it, but it's possible I may upgrade at a future date, although I find 1080p to be fine.
Note that I require an internal CD/DVD drive, and this limits the case to the one I've chosen. in turn, the case limits the CPU cooler, and this is one thing I would like advice on as the experts in this forum tend to advise against the PCS FrostFlow coolers. Finally, I do wish to use Windows 10, although I may take the next step when support ends. Any comments/suggestions on my build would be very welcome. Thank you.
Steveyg
Couple things mate first off the monitor is only fine because you haven't used a better monitor. Trust me it's not fine and upgrading the monitor to a 1440p 144hz IPS will GREATLY improve your experience
Secondly get an external disk drive, no need for internal drives and most cases simply don't support them anymore the same way they don't support floppy disk drives. I'll throw something together here hopefully get you the most bang for your buck and leave enough to get a proper monitor
Steveyg
This is where I'd go, almost leaves around £250 which should be enough to get a good monitor to suit
ASUS® TUF GAMING B660-PLUS WIFI D4: ATX, LGA1700, USB 3.2, SATA 6GBs - ARGB Ready
512GB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 3500MB/sR, 1625MB/sW)
1TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 2950MB/sW)
Corsair iCUE H100i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Price: £1,776.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/wRWTSyWqRQ/
Rubyjuno
Thanks for your answer, but as I said in my original post I need an internal DVD/CD drive, and that case doesn't support it.
sck451
There are essentially no good cases with internal drive bays. It's essentially impossible to make one because you end up putting a drive bay precisely where you want air to come into the case to cool the components. I'd strongly suggest that an external drive, connected by USB, will be a superior solution; it won't be any difference in the performance of the drive.
Is there any particular reason you specifically want an internal drive?
I would agree with @sck451 it's not worth sacrificing one of the most important aspects of the build to house legacy hardware.
Rubyjuno
Thanks for the replies. I understand the comments, but I've tried external drives and had nothing but trouble with them, and it's much more convenient having everything in on case. Would heat be such an issue with this build? Also, I'd really appreciate it if someone could tell me what the problem is with PCS FrostFlow CPU coolers, as everyone seems to be against them.
The 13600k TDP is too high for a frostflow, the pump wouldn't be sufficient to move the amount of liquid as was required.
Absolutely. 13th Gen pump out extraordinary amounts of heat and need absolutely premium cooling
This likely would have required troubleshooting or was an early external drive, I guarantee that's just not how things work these days.
