Please advise if this spec looks OK, advice on speedup, and USB3 question
Growltiger
I need a quiet PC but it needs to be powerful. Heavy duty photo editing, no gaming.
Q1. How does this spec look?
Q2. What speed do you think I could sensibly increase it to from 3.06GHz? I'm the most cautious type of overclocker, in the past I only changed BCLK (on an i7 920, from 133 to 166, giving 3.48GHz).
Q3. One other question, about the USB3. Is this just one USB3 socket on the back of the machine?
COOLERMASTER SILEO 500 QUIET MID TOWER CASE
Intel® Core™i7 Quad Core Processor i7-950 (3.06GHz) 4.8GTs/8MB Cache
ASUS® P6X58D PREMIUM: DDR3, USB 3.0 & SATA 6.0GB/s, 3-Way SLI
12GB KINGSTON HYPER-X TRI-DDR3 1600MHz, X.M.P (6 x 2GB KIT)
2GB NVIDIA GEFORCE GTX460 GDDR5 PCI EXPRESS - DirectX® 11
160GB Intel® X25-M 2.5" SSD (34nm / upto 250MB/sR | 100MB/sW)***SPECIAL***
10x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£88)
CORSAIR 850W TX SERIES (TX850) 80+ ULTRA QUIET PSU (£99)
COOLIT ECO A.L.C (ADVANCED LIQUID COOLER) (£59)
ONBOARD 10/100/1000 GIGABIT LAN PORT
Firewire & Video Editing
1 x IEEE 1394a FIREWIRE PORT ONBOARD
Mouse
Black Logitech® Optical Wheel Mouse USB (£5)
Speakers
LOGITECH Z323 2.1 Stereo speakers with Rich bass and 360-degree sound (£45)
Standard Build - Approximately 9 to 13 working days
Price: £1,618.00 including VAT and delivery.
Growltiger
Thanks Len. I assume the Fenrir comes with the fan installed and working? I had chosen the Coolit Eco because I thought I had been told it was better than the Fenrir. If the Fenrir is better (and cheaper) than that sounds best. Does anyone else have an opinion on this?
When I asked PCS previously they only overclock 6GB machines and I want 12GB. But this may no longer be the case. As I mentioned above I previously did my own overclocking experiments with a lot of sucess, getting 3.48GHz from the 2.66GHz 920 by changing just one setting (after installing a cooler like the Fenrir).
Phoenix
Yeah the titan fenrir does perform better and comes with the fan pre-installed and working although it is louder than the Coolit ECO. Getting a stable overclock with lots of RAM modules is harder to do which is why they won't be able to guarentee a high overclock. I can't really predict how far you personally will be able to take the CPU but just know that you'll void the warranty by doing this. There will be two USB 3.0 ports at the back of the computer.
Growltiger
Thanks, in that case I will definiitely get the Titan Fenrir.
The previous machine is an i7 920 with 12GB. I was very careful to monitor the temperature while running prime95 to make the system work flat out. Before I improved the cooling overclocking was not possible, the original speed was 2.66GHz.
Once I improved the cooling I was able to run it with BCLK=166, giving 3.48GHz. It was tested with prime95 running for at least 24 hours and with Realtemp reporting no more than 80 degrees. In normal use Realtemp is under 50. The system is completely stable and has been running for months.
The i7 950 starts at 3.06GHz. I'm assuming it will be possible to reach the same as the 920 managed, 3.48GHz, but perhaps it will go further.
I am very cautious. I never play with timings or voltages. The approach I have used seems simple and pretty safe.
Growltiger
Thanks for the info. I made a couple more small changes and ordered it (I decided against the SSD and got two of the 1TB drives instead.) Final price inc VAT £1297.
Now I just need to buy a monitor. You don't sell any 1920*1200 monitors so I'm looking elsewhere. I need a good quality one for photo work, the NEC LCD2490WUXi2 looks good though expensive.
