Pcs Onyx
frooomage17
I was looking for a new pc and was going to configure myself but realised there is more to consider then originally first thought.
After checking it out, I bought the PCS Onyx on an Easter deal with up to nearly £200 off the original cost if you were to configure it yourself and met the requirements I was looking for.
Came down in solid packaging and no damage whatsoever. Clear instructions of what's needed to do to get it up and and running.
Been using this for a couple weeks now for work and also gaming (I'm usually a console gamer) and this thing does not skip a beat and the graphics are so much more insane than a console. I love the RGB controllable lights and pretty much everything about this PC. I have not seen any other computers which match the specs for this price.
Thank you so much PCS, I would never buy a computer anywhere else!
FRACTAL FOCUS 2 ARGB GAMING CASE (BLACK)
Promotional Item
Intel® Core™ i5 10-Core Processor i5-14400F (Up to 4.7GHz) 20MB Cache
ASUS® PRIME B760M-A WIFI (mATX, LGA1700, DDR5, PCIe 4.0, Wi-Fi 6)
32GB Corsair VENGEANCE DDR5 5200MHz (2 x 16GB)
12GB NVIDIA GEFORCE RTX 4070 - HDMI, DP, LHR
Graphics Card Support Bracket
1TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 2950MB/sW)
CORSAIR 650W CX SERIES™ CX-650 POWER SUPPLY
ONBOARD LAN PORT
Wireless Router/HomePlugs
HomePlug 500 Mbps Starter Kit - Internet Through Powerline
Microsoft® Edge
