Pc stuck on spinning circle after having a blue screen.
Pxsickle
My pc had a blue screen saying I have a problem and the pc is restarting. When it came back on it followed it’s normal process but came to this point where it stayed for hours. Does anyone have a fix for this.
(Stuck spinning this white circle)
I can enter bios.
I can enter bios.
Can you post your full specs from the order page?
Pxsickle
Yes, here are my specs:
Cpu
AMD Ryzen 3 3200G Quad Core CPU with Vega Graphics (3.6GHz-4.0GHz/6MB CACHE/AM4)
ASUS® PRIME A320M-K: Micro-ATX, AM4, USB 3.0, 6GB/s
Ram
8GB Corsair VENGEANCE DDR4 2400MHz (1 x 8GB)
Graphics card
4GB NVIDIA GEFORCE GTX 1650 - HDMI
Cpu
Ram
Graphics card
We'd need the full specs please
Pxsickle
Would this be sufficient?
Cpu
Ram
Graphics card
256GB ADATA SX6000 Pro PCIe M.2 2280 (2100 MB/R, 1200 MB/W)
STANDARD AMD CPU COOLER
Windows 10 Home 64 Bit -
While you are booting press f2 repeatedly to get into the bios and in there you should see a list of boot devices
Interesting note (ok, not really), I tap the key rather than holding it down. The key repeat rate of holding it down is pretty high and when you get into the bios the beeping does my head in.
Tapping the key means that the repeat is far reduced 😬
Might blow you mind here mate but you don't have to bash the key you can simply hold it down
What??? I've always bashed it, it's like a right of passage, you have to Don a white robe, anoint yourself in the blood of lambs... and bash the key!
I will be holding it from here on! I'll still dress in robes though and the lambs blood is just a good look.
Personally I use the force. I've found that if I concentrate really hard I can almost imagine that the key presses itself. But I'm still a novice so I've not quite managed to do it yet.....
