JamessyBee
Hey guys, I’ve recently bought a new build to upgrade for myself. My old PC is going to a friend, but the CPU has a temperature issue hitting 89 Celsius. Her friend is going to put new thermal paste as well as a new CPU fan in for her.
If that doesn’t fix it, it’s looking like replacing the CPU. What would anyone suggest? Buy the same CPU currently in the build or would anyone suggest a newer CPU that is compatible with the current build?
She can’t really afford to change everything up so would need recommendations with just the CPU please.
Specifications:
PCS SPECTRUM RGB MID TOWER CASE
Intel® Core™ i7 Eight Core Processor i7-9700K (3.6GHz) 12MB Cache
ASUS® ROG MAXIMUS XI HERO: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready
8GB NVIDIA GEFORCE RTX 2070 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
1TB Samsung 860 QVO 2.5" SSD, SATA 6Gb/s (up to 550MB/sR | 520MB/sW)
CORSAIR 650W VS SERIES™ VS-650 POWER SUPPLY
PCS FrostFlow 240 Series RGB High Performance Liquid Cooler
LED Lighting
50cm UV LED Strip
Specifications:
LED Lighting
50cm UV LED Strip
