Here's a few examples of Teaz's recent delivery , you may be able to request cable sleeves at a slight extra cost possibly, you'll have to give them a ring on 0844 499 4000 or email them asking. Hope this helps somewhat.
Steve
Edit:
The first image is off the underside of the Mobo, the side where the most of the airflow is achieved is the 2nd picture
so in the second image, those are default from pc specialist ?
thanks man nice pc btw. how much it set you back
In reply to your other thread "cold cathode voltage"I said said it depends on how many & what size.If my max power usage is 401 with 20% increase. Will cold cathodes and new fans increase it that much?
You should be fine with your 450W PSU.oh thanks i was looking at kits but they didnt say. so they wont really affect my power requirement
LoL i'll have to contradict you a bit there steve as the second image was not default cable management by pcs, that is my own doing as most of cables when first received was lodged in my hdd bay and wiring was more erratic i just didnt grab a picture from the front as it instantly RMA-ed lol
