Hi
My nephew is wanting a PC for his xmas and im trying to configure one that will be good enough to last a few years.
He will be using it mainly for Minecraft, tekkit, Dragon age games, DC Universe, rift and skyrim etc
I had a look at the pre built PCs and the Cyclone V looked ok so I used that as a starting point and changed 1 or 2 things and came up with this -
Case COOLERMASTER ELITE 430 BLACK CASE
Processor (CPU) Intel® Core™i5 Quad Core Processor i5-3570 (3.4GHz) 6MB Cache
Motherboard ASUS® P8Z77-M: MICRO-ATX, USB 3.0, SATA 6GBs, ATI®CrossFireX
Memory (RAM) 8GB KINGSTON HYPERX GENESIS DUAL-DDR3 1866MHz X.M.P(2 x 4GB KIT)
Graphics Card 2GB NVIDIA GEFORCE GTX 660 - DVI, HDMI, VGA - 3D Vision Ready
Memory - 1st Hard Disk 2TB 3.5" SATA-III 6GB/s HDD 7200RPM 64MB CACHE
Power Supply 450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
Processor Cooling INTEL SOCKET LGA1155 STANDARD CPU COOLER
Sound Card Asus Xonar DG 5.1 SoundCard & Headphone AMP (Award Winner) (£22)
Network Facilities 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
Operating System Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence (£79)
Total Order Price £785.00
What do you think of this? was trying for £600 to £700 so im over my intended budget. would this be ok to handle those games and manage newer ones over the next few years?
is there anything that I should change? I wasnt sure about the graphics card or processor.
Any advice would be great.
JJ
JJ
