Dragosanii
Hi all,
Coming back to the forums to get some advice as my rig is overheating (again) under normal operation (playing 1 game, different games, nothing else open)....
My spec first:
Case NZXT PHANTOM 410 WHITE GAMING CASE
Processor (CPU) AMD FX-9370 Eight Core CPU (4.4GHz-4.7GHz/16MB CACHE/AM3+)
Motherboard ASUS® SABERTOOTH 990FX R2.0 (DDR3, USB3.0, 6Gb/s, CrossFireX/Sli)
Memory (RAM) 32GB KINGSTON DUAL-DDR3 1600MHz (4 x 8GB)
Graphics Card 4GB AMD RADEON™ R9 290X - DVI, HDMI, DP - DX® 11, Eyefinity 4 Capable
1st Hard Disk 120GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd Hard Disk 2TB 3.5" SATA-III 6GB/s HDD 7200RPM 64MB CACHE
1st DVD/BLU-RAY Drive 16x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW
Power Supply CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling Corsair H80i Hydro Series High Performance CPU Cooler
Change to: ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
The issue:
Playing The Division (all gfx etc set to medium), after about 30 minutes, the heat pouring out of the side of my case is insane...the LED on the Corsair H80i Hydro goes from sky blue (normal) to white then to red and the pc shuts down soon afterwards....
When I feel the cooling pipes, they are VERY hot....
If I shutdown the game during this process, the rig cools down after about 3 minutes or idling and the LED colours return to normal.....
I did have an issue after I bought this with the H80 Water cooloer, which was RMA'd and PCSPEC kindly upgraded to the H80i.....But I'm wondering if this is starting to go faulty again?
I downloaded an Open Hardware Monitor piece of software and also run the Corsair Link software to monitor what is going on, and it does look like the cooling unit is not cooling as it should be. The link software says the pumps are running ok and the fans are running ok....but it just doesn't seem to be cooling when I'm playing some games.....
The games this doesn't happen: Wildstar, Overwatch, GTAV, Elite
angerous, The Witcher 3 (although this can be heavy on the gfx side) and anything with not too much heavy load on the system.
Games it happens with: The Division, Sniper Elite 3, No Man's Sky (Do Not Buy), Hurtworld, Payday 2.....
I keep my rig fully protected from virus and malware, fully up to date with security patches (Windows 10 64bit) and the latest video drivers (currently running AMD Radeon version 16.8.2)......
Any ideas? Thanks in advance....
- Drago
My spec first:
The issue:
- Drago
