Hello Paul
About a year ago I received a lovely PC from PCSpecialist. I rarely put the system to 'sleep' because it usually does not wake up again. But I did just do exactly that - I made sure I didn't have anything (other than Google Chrome and Filemail) running, because I suspected it might not wake up again. About half an hour later, I tapped the spacebar to wake it....wiggled the mouse....the internal LED lighting in the PC's case came on, and the "DisplayPort" message appeared on one of my monitors, but other than that, the screens remained black on all three monitors, ignoring my random key presses. I waited a while....the lights in the case remained on, just doing their usual thing...fans running as normal, but nothing on the screens, as per usual when trying to wake from sleep. After a couple of minutes I pressed the reset button to force a restart, and the system powered up as normal.
I last updated Windows 10 a few days ago, but this issue has been plaguing me for months. My workaround is to just not put the system to sleep, but shut it down or leave it running for short periods of non-use (I have my monitors set to sleep after 15 minutes or so).
Does anyone have any suggestions what might be causing this?
Thanks in advance for any help!
~ Paul
My specs:
Edition Windows 10 Home
Version 21H1
Installed on 19/04/2021
OS build 19043.1586
Experience Windows Feature Experience Pack 120.2212.4170.0
I'm on Nvidia driver version 511.79 (updating that to 512.15 right now).
CORSAIR 5000D AIRFLOW TEMPERED GLASS GAMING CASE
AMD Ryzen 9 5950X 16 Core CPU (3.4GHz-4.9GHz/72MB CACHE/AM4)
128GB Patriot Viper Steel (4 x 32GB) DDR4 PC4-28800C18 3600MHz (NOT from PCSpecialist, but Overclockers UK)
24GB ASUS ROG STRIX GEFORCE RTX 3090 - HDMI, DP
8TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
~ Paul
My specs:
Version 21H1
OS build 19043.1586
