Pc not running properly (music production)
ddr305
I bought my pc in August last year and I'm having some issues with it. Namely FL Studio constantly crashing under little to no strain at all and I get crackles and pops in audio from time to time. All software is up to date and I've always installed windows updates as and when they appear. Below is my spec.
AMD Ryzen 7 3800X Eight Core CPU (3.9GHz-4.5GHz/36MB CACHE/AM4)
2GB NVIDIA GEFORCE GT 1030
1TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
Firefox™
Monitor
AOC U2879VF 28" 4K Monitor - 3480 x 2160, 1MS, HDMI, DVI, DP
LOGITECH® K120 USB KEYBOARD
LOGITECH® OPTICAL USB MOUSE
Standard Build - Approximately 22 to 24 working days
Promotional Item
Get Assassin’s Creed® Valhalla with select AMD Ryzen CPUs
Welcome Book
Logo Branding
PCSpecialist Logo
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/2caSPCR4Y5/
do you use an external audio interface of some sort? does the CPU/RAM usage spike while using FL? Crackling usually is produced when CPU spikes up. Any other software not working properly?
Additional to this, have you got it plugged into a surge protector? If so try it plugged directly into the wall or vice versa (it needs to be in a surge protector) that will tell you if the surge protector is compromised.
Regarding the crashing, open an elevated command prompt or PowerShell session and enter the command sfc /scannow. What does the output say?
