PC I'm ordering!
JoeHowse
I'm ordering my new pc in a couple of days and wanted to know what you all think? :tt2:
I know its overkill but I want it to be very futureproof, anyway here are the specs:
COOLERMASTER HAF-X FULL TOWER GAMING CASE
Intel® Core™i7 Six Core Processor i7-3930K (3.2GHz) 12MB Cache
ASUS® RAMPAGE IV EXTREME: INTEL X79, SOCKET 2011, R.O.G
16GB KINGSTON HYPERX BEAST QUAD-DDR3 2400MHz X.M.P (4 x 4GB KIT)
4GB NVIDIA GEFORCE GTX 680 - 2 DVI, HDMI, DP - 3D Vision Ready
2nd Graphics Card
240GB INTEL® 335 SERIES SSD, SATA 6 Gb/s (upto 500MB/sR | 450MB/sW)
4x BLU-RAY ROM DRIVE, 16x DVD ROM (£26)
CORSAIR 1050W PRO SERIES™ HX1050-80 PLUS® GOLD MODULAR (£159)
Corsair H100 Hydro Series High Performance CPU Cooler (£89)
Creative Sound Blaster Recon3D PCI-E Soundcard (£46) *SPECIAL*
WIRELESS 802.11N 300Mbps PCI-E CARD (£16)
Genuine Windows 7 Professional 64 Bit w/SP1 - inc DVD & Licence (£109)
Microsoft® Office Home & Student 2013 (1 License Key Card) (£95)
NORTON ANTI-VIRUS 2013 - 1 Year Licence for 1 PC (£9) *SPECIAL*
Monitor
BENQ XL2411T 23.6" GAMING LED - 1920 x 1080, 1MS, DVI-D, HDMI (£239)
DVI-D & HDMI Monitor Cables
2 x 2 METRE DVI-D CABLE (£9)
Razer® Deathstalker Expert Gaming Keyboard (£69)
Speakers
Creative A220 2.1 Speakers with Subwoofer (£28)
For gaming definitely overkill (motherboard, cpu and gpu if gaming in 1 screen). I think that if you want to futureproof your system I would spend a fraction and just upgrade after a couple of years. Considering how much you are spending in your system I'd suggest upgrading your warranty, parts are only covered by 1 year on silver warranty.
vanthus
Member Resting in Peace
That's quite a beast,if your going to go the full hog,get a caviar black as second hard disk.
If it's for gaming though it is pretty much overkill in almost every department.
As far as future proofing goes it's not guaranteed to be worth the money.
Niem
Agree with Keynes, You can get a 'future proof' build for a fraction of the price.
Could go with an i7-3770, GTX 680 (2GB) SLI or even a 670 SLI.
Outerarm
Looks very similar to a high-end spec I'm putting together. I decided on a 690 instead of the two 680s, a caviar black as the second hard disk, a r/w blu-ray drive and three monitors. It is expensive but it is the only computer purchase I'll be allowed to make for 6 to 8 years so I'm making the most of it. Like you I'm aiming for future proofing the solution, though I will be using the rig for graphics work (3D renders) and video encoding. Edit: Oh, and gaming as well!
Toxophilix
Both the HDD and SSD look like they've escaped from another spec. Right now they looking around in wide-eyed amazement, whispering, daring each other to be the first to speak to the CPU.
