PC for Image Scanning and Processing
oimee
Hi there - I need a PC that will be used primarily for image processing, photo editing, adding metadata on image batches, scanning using Nikon scan software and mild editing in Photoshop.
Do you think this spec will do the job? It doesn't need to be a powerful workhorse, but needs to handle the above consistently. My now defunct PC was running my software fine on XP - but can upgrade to Win7 if recommended.
I've opted below for the i3-4340 but have considered the i5-4670 too - any advice on which would work better for me is greatly appreciated.
Thanks in advance!
STYLISH PIANO BLACK ENIGMA MICRO-ATX CASE + 2 FRONT USB
Intel® Core™i3 Dual Core Processor i3-4340 (3.60GHz) 4MB Cache
ASUS® H81M-E: Micro-ATX, LG1150, USB 3.0, SATA 6GBs
4GB KINGSTON DUAL-DDR3 1600MHz (1 x 4GB)
500GB WD CAVIAR BLACK WD5003AZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
INTEL STANDARD CPU COOLER
DVD Recovery Media
NO DVD RECOVERY MEDIA REQUIRED
Cadwah
Rising Star
The i5 would be better but obviously this comes at increased cost. I would also consider the 1TB Caviar Black as it's only an extra £10-15
