Hello
My spec is for running real time 3d rendering software (twinmotion 2). The difference with realtime is it works more like a game engine, so renders are instant. This also means that instead of a CAD workstation styled spec, I can go for a gaming pc.
I have chosen the 3gb 580 as opposed to a 590 as the main 2 realtime renderers right now can use that 3gb of memory, but would only use half of the 590's (using only 1.5gb)
I did want the next motherboard model up but this stops me from fast tracking delivery, is this important?
Also I wanted lightscribe but this website doesn't give it as an option. But on the other hand it's hard to get quoted a spec with the 3gb model of the 580, so I had to compromise! :winkiss:
Oh and one last thing, I did have a higher powered PSU, but the site pop up advised me I only needed 600w. I assume the people at pcspecialist are right! But I'm just double checking.
Here's the spec:
Case PCS MAELSTROM T900 BLACK GAMING CASE
Processor (CPU) Intel® Core™i7 Six Core Processor i7-980 (3.33GHz) 4.8GTs/12MB
Motherboard ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
Memory (RAM) 12GB KINGSTON HYPER-X TRI-DDR3 1600MHz, X.M.P (3 x 4GB KIT)
Graphics Card 3GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready
Memory - 1st Hard Disk 1TB WD CAVIAR BLACK WD1002FAEX, SATA 6 Gb/s, 64MB CACHE
(7200rpm)
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply 600W Quiet 80 PLUS Quad Rail PSU + 120mm Case Fan (£59)
Processor Cooling COOLIT ECO A.L.C (ADVANCED LIQUID COOLER) (£49)
Network Facilities ONBOARD GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI CARD (£16)
Operating System Genuine Windows 7 Professional 64 Bit - inc DVD & Licence (£109)
Warranty 3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year
Labour)
Build Time FAST TRACK 5 WORKING DAY DISPATCH (£39)
Price Ex VAT £1380.83
Price £1657.00
Here's the spec:
(7200rpm)
Labour)
Price £1657.00
