pc cooling help?
Bsrz
Rising Star
Hi everyone! just a very quick question will my pc run cool using the haf-x full tower case with the fans full blast, and also I was looking at the cpu coolers since Im buying the 3770k and the triple copper heat pipe is the only one I can see that is not water cooling, so I need your honest opinion on how good of a job will the heat pipe do, and can anyone tell my the brand / the exact model used??? I really want my pc to run nice and cool with out water cooling - dont trust it. thanks all.
MadMan
Super Star
I have that cooler and it cools my pc well. The highest I've ever seen it was 50c I think. The make is Titan I think. It should be more than enough. If your going to over clock then consider water cooling. Otherwise air cooling is sufficient.
tom_gr7
Life Serving
hi again lol.
Totally get you with the concerns of liquid coolers, although most are very safe nowdays!
The triple copper cooler is good enough to keep a cpu cool at stock speeds.
If you are going for a K version and the temptation of OC'in sets in, then you will need to get a much stronger air cooler. Many out there, but they are massive AND it's not ideal having a big air cooler in a rig thats getting delivered!
Ya will have to have a google, noctua, phanteks, bequiet do some good coolers.
Bsrz
Rising Star
ah ok thanks guys, not sure about over clocking yet, I think I will stick the the triple copper for now and if in the future I want to over clock or I feel temps are to high i will invest in a beefy cooler, But I will never water cool :p unless air coolers no longer exist :D
