very nice package thereHi there! Assuming Whole setup means PC, monitor, keyboard, mouse, headset- this should do them nicely.
For monitor, I own the AOC CQ27G2U and am very happy with it. It’ll match nicely with the 3060TI. For the other peripherals, I’ve just added the ASUS bundle from PCS for now. It gives you a decent set of peripherals to get you going as these are the easiest things to upgrade over time. If you wanted to do some research and buy separately, the budget allows about a £130 spend on these.
Any questions, ask away!
COOLERMASTER MASTERBOX TD500 MESH ARGB GAMING CASE Great airflow case
AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4) The gaming CPU to have right now
ASUS® TUF GAMING B550-PLUS WiFi (DDR4, USB 3.2, 6Gb/s) - ARGB Ready! Solid midrange motherboard that’ll pair nicely with the 5600X, also has WiFi
16GB Corsair VENGEANCE DDR4 3600MHz (2 x 8GB) 16GB will be ample for most games, AMD loves fast ram hence the 3600mhz.
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP, LHR very nice graphics card for 1440p gaming
2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE HDD for general file storage or less played games
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW) Super fast 500GB SSD for windows and applications
1TB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W) A dedicated games drive
CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET top quality power supply that’ll happily allow for upgrades down the line
CoolerMaster Hyper 212 (120mm) Fan CPU Cooler Black Edition all the cooling the 5600X will need
NO ANTI-VIRUS SOFTWARE Windows defender is just fine
ASUS TUF Gaming K1 Keyboard, M3 Mouse & H3 Headset Bundle
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) Well worth the £5
Standard Build - Approximately 14 to 17 working days
Price: £1,691.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/aVmJweQTGe/
Are you the friend of the OP? If not, please start your own thread, piggybacking on another person’s thread is discouraged here.Can this work? Im thinking of getting this one..
Thanks for the help. Could you do one with £2k max for the PC please?Hi there! Assuming Whole setup means PC, monitor, keyboard, mouse, headset- this should do them nicely.
Sure! What monitor would it be paired with? Sticking with 1440p 144hz?Thanks for the help. Could you do one with £2k max for the PC please?
