hannahmacca
Hi I'm looking to get a PC built for motion and 3D work, with my limited knowledge of what goes on inside a pc, I've asked around for what's best and selected the following spec. I've been told to get as many Cudas as you can and to make sure you've got enough cooling. I personally would like a quiet machine too. I've maxed out my budget (really i was trying to get closer to £2k).
What do you think of this? Does anything conflict? Could I do with tweaking things here and there? Is there anything unessessary? Is it sufficient for 3D rendering. Thanks in advance for any advice you have
FRACTAL POP SILENT CASE TG (BLACK)
Intel® Core™ i9 24-Core Processor i9-14900F (Up to 5.8 GHz) 36MB Cache
ASUS® PRO WS W680-ACE (LGA1700, DDR5, PCIe 5.0)
64GB Corsair VENGEANCE DDR5 5600MHz CL40 (2 x 32GB)
16GB MSI GEFORCE RTX 5080 SHADOW 3X OC - HDMI, 3 x DP
2TB PCS PCIe M.2 SSD (3500 MB/R, 3100 MB/W)
PCS FrostFlow 200 Series High Performance CPU Cooler
ONBOARD LAN PORT
Trusted Platform Module (TPM)
Asus TPM-SPI
ONBOARD LAN PORT
Asus TPM-SPI
