Hey guys, a friend of mine would like a gaming pc so I thought I would consult with the experts to get the best build possible. He already has a screen, mouse and keyboard so the budget is just for the pc. Thanks in advance
Intel Build:
If you can squeeze another £70 into the budget you can get a 970, or to stay in budget change it out for a 960. Personally I would try and go for the Intel build, although with the AMD build you might be able ot juggle the hard drives and squeeze a 120 SSD in the primary with a secondary HDD as well. Your choice.
Intel® Core™i5 Quad Core Processor i5-4690 (3.5GHz) 6MB Cache
InWIN GT1 BLACK GAMING CASE
ASUS® Z97-E: ATX, USB3.0, SATA 6GB/S, SLi, XFIRE
8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
4GB NVIDIA GEFORCE GTX 970 - 2 DVI, 1 HDMI, 1 DP - 3D Vision Ready
1st Hard Disk
Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler (£19)
Windows 10 Upgrade
FREE Upgrade to Windows 10 with all Windows 7 & Windows 8.1 Purchases*
AMD Build:
In budget, personally I would squeeze the budget and go for the Intel build.
AMD A10-7870K Quad Core APU (3.9GHz) & Radeon™ R7 Series Graphics
ASUS® A68HM PLUS FM2+ (M-ATX, DDR3, USB 3.0, 6Gb/s)
1st Hard Disk
Super Quiet Titan DragonFly Heatpipe AMD CPU Cooler (£19)
Windows 10 Upgrade
