PC Build Advice
aiai
Hey!
Looking to move off a gaming laptop I bought 10 years ago onto a PC and I'm not too sure what I'm doing, so any help would be appreciated!
Usually use the PC mostly for gaming (FFXIV being the main, and various things off steam), and watching movies and the like
I currently have this monitor --> https://www.overclockers.co.uk/b-gr...um-dot-165hz-1ms-freesync-g-bg-mo-015-ms.html
I had a go at specing a PC and I'm not too sure if it is a good build? Any opinions would be appreciated! :)
CORSAIR iCUE 5000T RGB MID TOWER GAMING CASE
Promotional Item
Buy select GeForce RTX 40 Series*, get Black Myth: Wukong
Intel® Core™ i7 20-Core Processor i7-14700K (Up to 5.6GHz) 33MB Cache
ASUS® ROG STRIX Z790-A GAMING WIFI D4 (LGA1700, DDR4, PCIe 5.0, Wi-Fi 6E)
8GB PCS PRO DDR4 3200MHz (1 x 8GB)
16GB ASUS TUF GEFORCE RTX 4080 SUPER OC EDITION - HDMI, 3 x DP
Graphics Card Support Bracket
1TB CORSAIR FORCE MP600 NVMe PCIe M.2 SSD (up to 4950 MB/R, 4000 MB/W)
4TB CORSAIR MP600 PRO NVMe PCIe M.2 SSD (up to 7000 MB/R, 6850 MB/W)
Braided Power Supply Cables
CORSAIR Premium Individually Sleeved PSU Cable Kit Pro (40 Series) - Black
CORSAIR ICUE LINK H150i RGB HIGH PERFORMANCE CPU COOLER
3 x Corsair ICUE LINK QX120 RGB PWM Fan + Controller Kit
ONBOARD LAN PORT
2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS
SUNDAY DELIVERY TO UK MAINLAND (BEFORE 2PM)
Price: £3,519.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/aKZ9GmY4bJ/
Ekans2011
Hey!
Promotional Item
ONBOARD LAN PORT
Hi, what's your max budget? Intel must be avoided at all cost.
Ekans2011
Ah sorry just saw the link you posted - interesting. Cool AMD it is!
I'd go for something like that as a very high-end QHD/1440p gaming PC, but if you’re not in an absolute rush, the next gen 9000X3D should be released in September along with new X870/X870E motherboards and new GPUs shortly after.
I would personally hold off until the next gen are released. It's your decision. :)
CORSAIR iCUE 5000X RGB MID TOWER GAMING CASE - Better value than 5000T, , with better/newer fans installed
AMD Ryzen 7 7800X3D Eight Core CPU (4.2GHz-5.0GHz/104MB w/3D V-CACHE/AM5) - Best gaming CPU on the market
ASUS® TUF GAMING X670E-PLUS WIFI (AM5, DDR5, PCIe 5.0, Wi-Fi 6E) - Solid MB, more than enough to handle that CPU
32GB Corsair VENGEANCE DDR5 6000MHz (2 x 16GB) - Frequency sweetspot for AM5
16GB NVIDIA GEFORCE RTX 4070 Ti SUPER - HDMI, DP, LHR - Top-tier QHD/1440p GPU
512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 4700MB/sW) - Small, fast OS Drive
2TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 3325MB/sW) - Main drive for games (no need ultra high read/write sequential speed for games)
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET - ATX 3.1, transient spikes protection, better efficiency at low loads, plenty for future GPU upgrades (unavoidable).
CORSAIR ICUE LINK H115i RGB HIGH PERFORMANCE CPU COOLER - Premium 280mm AIO, already overkill for the 7800X3D
STANDARD THERMAL PASTE FOR SUFFICIENT COOLING - Corsair XTM70 is even better than Mx-4
3 x Corsair ICUE LINK QX120 RGB PWM Fan + Controller Kit - Mainly aesthetic, need to be properly configured to maximise the airflow
ONBOARD 2.5Gbe LAN PORT
NO ANTI-VIRUS SOFTWARE - Norton only slows down the system
Firefox™ - Non-Chromium based browser
3 Year Gold Warranty (2 Year Collect & Return, 2 Year Parts, 3 Year Labour) - I guess Gold should be enough, it's up to you
Price: £2,594.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/eAUsBm7hGq/
