PC beeping on startup
Fiinch
I recently got a new PC, and everything seems to be running great. I haven’t ran into any issues yet, however every time I boot it, it makes a short beeping noise.
Just wondering if this is normal as I’ve never heard any PC make this noise before.
Fiinch
Is the new PC from PC Specialist? Can you post your specs from your account?
Yeah it’s a new PC from PC Specialist - I got it just a couple of days ago
These are the specs:
CORSAIR CRYSTAL SERIES 280X RGB GAMING CASE (Special Offer)
GIGABYTE B550I AORUS PRO AX: DDR4, USB 3.2 - ARGB Ready
4GB NVIDIA GEFORCE GTX 1650 - HDMI
256GB PCS 2.5" SSD, SATA 6 Gb (500MB/R, 400MB/W)
2nd Storage Drive
CORSAIR 550W CV SERIES™️ CV-550 POWER SUPPLY
STANDARD AMD CPU COOLER
LED Lighting
2x 50cm RGB LED Strip
GIGABIT LAN PORT + Wi-Fi (Wi-Fi excluded on A320I-K)
Windows 10/11 Multi-Language Recovery
FREE 30 Day Trial of Microsoft 365®️
BullGuard™️ Internet Security - Free 90 Day License inc. Gamer Mode
Google Chrome™️
Rakk
The Awesome
If its just one beep then as Salmon Fisher said, that'll be the POST beep and is expected and is basically your PC saying 'ok, I am good to go'
More than one beep is an error code, but just one is perfectly fine
Fiinch
It’s just one beep, so that’ll be it then. Thanks for the help
