If you take it off you will need to reapply thermal paste. If its already off you will also need to do this.
I took the back off the laptop, the heatsinks were both screwed down tight so I didn't bother with them. I just used half a can of compressed air to give the heat sinks, copper and fans a good clean. Seems to have done the trick.
