Overclocking Failed
Hi all,
Had this message appear after the computer went into some hibernate state with a blinking power button and refused to 'wake up', forcing a reboot. No overclocking is active and I suspect it's some kind of issue with waking the thing up after the sleepbut thought I'd check to see if anyone else has had it.
It rebooted fine afterward and I've set up a power plan without sleep mode to see what happens in the meantime.
PCS
Administrator
Staff member
This is a standard motherboard message - no overclocking has failed because as you said we haven't overclocked your computer. You can continue as normal, you will only see this message when you restart your PC wiothout shutting it down correctly.
