OS installed on the wrong hard drive
Scottmask
Hi Guys,
i selected a 500gb ssd as my 1st drive and 1000gb ssd as my 2nd drive but PCS have still installed the OS on my 1000gb SSD.
is this an easy process? i didn't want to have to be re-installing an OS on the first day of receiving my machine which is slightly annoying.
any help would be appreciated.
thanks,
Rakk
The Awesome
I guess mistakes do sometimes just happen if they've installed it on the second selected drive, but installing windows is actually quite simple now-a-days (not like it used to be) you'll be pleased top know
You can create a media installation on a USB stick and install from that - just use the instructions here : https://www.microsoft.com/en-gb/software-download/windows10
Scottmask
Case CORSAIR CRYSTAL SERIES 680X RGB GAMING CASE
Memory (RAM)32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (2 x 16GB)Graphics Card10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP (Xmas delivery not guaranteed)
Change to: 10GB ASUS ROG STRIX GEFORCE RTX 3080 - HDMI, DP
1st Storage Drive4TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 5400RPM, 256MB CACHE
1st M.2 SSD Drive1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
Change to: 500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W)
2nd M.2 SSD DriveNONE
Change to: 1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Memory Card ReaderUSB 3.0 EXTERNAL SD/MICRO SD CARD READER
Change to: CORSAIR 1000W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Windows Recovery MediaWindows 10 Multi-Language Recovery Image - Supplied on USB Drive
BrowserGoogle Chrome™
Warranty3 Year Gold Warranty (2 Year Collect & Return, 2 Year Parts, 3 Year Labour)
Change to: SATURDAY DELIVERY TO UK MAINLAND (BEFORE 2PM)
Build TimeStandard Build - Approximately 13 to 15 working days
Promotional ItemGet Assassin's Creed: Valhalla with select SAMSUNG SSDs!
Promotional ItemGet FarCry 6 with select AMD Ryzen CPUs
Promotional ItemGet CoD:Cold War & 1YR GeForce Now w/ select RTX Graphics Cards
Deleted member 17413
Wait, ive just thought about what I was thinking about and I totally forgot we are talking the OS here...
I dont think you can just import it across with magician lol
You will want to download samsung magician from the Samsung website, your M.2 SSD's have extra features that the software will allow you to enable.
Samsung magician also has the ability to copy a drive contents over onto another samsung drive, but its the OS system, so I dont think its actually possible to just move it like that (not unless Samsung really is a magician)
But you still want the software, you'll be able to enable full power mode on the 980 Pro's.
Scottmask
okay thank you mate i'll download it but i have a feeling i'll have to download it again shortly :)
Scottmask
okay thank you i've got a spare 16gb memory stick so i hope that's big enough.
is there anything in particular i need to ensure is reinstalled after i re-install windows?
thanks,
Easiest way is to prep yourself a install stick
Have you got a decent USB drive lying around?
Turn it into a boot USB using Media Creation, then once thats done, create an extra folder on it and stick all the setup stuff you need.
You want to download a copy of the Ryzen chipset & driver tool, Armoury Crate, Nvidia GPU drivers (personally I would do a manual search, custom install without experience or audio ticked), Corsair iCue (im using 3.8, havent switched to 4 yet....anyone know what its like?) and Samsung Magician
Do the windows install, run the Ryzen chipset update, run windows update to death and reboot an extra time at end to make sure it offers you no more, install the GPU drivers, then armoury crate, then iCue and the samsung...then spend hours tweeking everything to how you want it.
Rakk
The Awesome
thanks,
16Gb is enough, as you only need at 8GB for it, make sure there's nothing on the USB stick you want to keep though as the whole thing will be wiped.
You'll need to make sure you run Windows Update multiple times to make sure its finds everything, but you'd have to do that anyways normally
Are you using your windows account, or have you logged into your windows account to associate the licence?
Do that before you reinstal, then in Windows setup use your windows account login and it will allow you to activate that way.
Ok i can see what happened, they installed the OS on the fastest drive as per normal practice, thee 1TB is 100MB faster.................
Yeah, I thought that too. I think for future spec helping we should advise that they log it on live chat which M.2 they want it on if there’s a drive speed discrepancy.
