Ordering Next Week...FINALLY!!!
kaptainkillyou
OK guys so here is a very revised (on editor at least five times a day) spec. Main uses will be intensive video/photo editing, (gaming, don't tell the Mrs) and graphic design work. What do you all think? Anything lacking or extra that's cool you would recommend?
COOLERMASTER CM STORM TROOPER - GAMING ENTHUSIAST CASE
Intel® Core™i7 Quad Core Processor i7-3770 (3.4GHz) 8MB Cache
Price: £1,408.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/quotes/intel-ivy-bridge-pc/EvV3JASNkj/
Other components will be:
ASUS XONAR D2X sound card
DELL U2410 and BENQ XL2420T monitors
NVIDIA 3D VISION 2 kit
LOGITECH X530 5.1 speakers
RAZER CARCHARIAS headset
LOGITECH G510 keyboard
CYBORG RAT 7 mouse
ROCCAT TAITO MID mouse mat
All for a grand total of £2376.90!
So what do you think?
Very nice :)
I'd check the compatibility of your monitors with nvidia 3d vision though, you could also go for a modular PSU for better cable management/airflow but not essential.
Grinder
Do you intend on adding a second gpu for Sli?
If not then you can downgrade the mobo and PSU.
Everything else looks great :)
kaptainkillyou
I know that the BenQ monitor is compatible and I know the Dell isn't. The dell is an IPS so that will be my monitor for the work side of things and the BenQ is purely for FUN :)
I do intend to add another GTX 670 in a year or so if it starts getting tired at the latest games then. Why the downgrade on the mobo?
