Options for a cheap-as-chips low-end gaming rig?
Outerarm
My kids are starting to get into Minecraft and the Lego games and I'm toying with the idea of getting them a cheap and cheerful rig. I'm looking for something that could push out around 60 fps at 1280x1024 with high settings on Minecraft, Lego and other lower-end games. I'd need an OS (and preferably home office), and would like a DVD drive and around 500GB disk space. No need for wireless and a built-in sound controller would be fine, though some options for upgrading would be nice. I already have a monitor, keyboard and mouse.
Bearing all that in mind... what suggestions do you have for a spec?
Thanks in advance,
Ian
GeorgeHillier
Thanks in advance,
Ian
What's your budget?
Outerarm
Well my local take away does chips for £1.50, so I assume around that sort of level...
:D
Yup, pretty much that!!!
For the budget I'm probably in the £300 to £400 range, but could go slightly higher if there is a significant improvement in the spec.
GeorgeHillier
For that price you won't be able to run those games on high, you'd be able to run them, just not on high settings.
GeorgeHillier
Here's a build that will be able to run minecraft and lego games with ease on around medium settings, it does cost £516 so if you wanted to get it back into your budget then you'd have to get rid of some stuff, but I would advise against it:
Case InWIN G7 BRUSHED EFFECT DARK GREY CASE
Processor (CPU) AMD A10-7700K Quad Core APU (3.8GHz) & Radeon™ R7 Series Graphics
Motherboard ASUS® A88XM-PLUS: (M-ATX, DDR3, USB 3.0, 6Gb/s)
Memory (RAM) 8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
Graphics Card Integrated AMD Radeon HD 8000 Series Graphics
2nd Graphics Card NONE
1st Hard Disk 500GB 3.5" SATA-III 6GB/s HDD 7200RPM 16MB CACHE
2nd Hard Disk NONE
3rd Hard Disk NONE
4th Hard Disk NONE
RAID NONE
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader NONE
Power Supply CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
Processor Cooling Super Quiet 22dBA Triple Copper Heatpipe AMD CPU Cooler
Extra Case Fans NONE
Wireless/Wired Networking 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
Modem NONE, I WILL BE USING BROADBAND
Firewire NONE
TV Card NONE
Operating System Genuine Windows 8.1 64 Bit - inc DVD & Licence
DVD Recovery Media Windows 8.1 (64-bit) DVD with paper sleeve
Office Software FREE 30 Day Trial of Microsoft® Office® 365
Anti-Virus BULLGUARD INTERNET SECURITY - FREE 90 DAY TRIAL
Monitor NONE
2nd Monitor NONE
3rd Monitor NONE
4th Monitor NONE
DVI-D & HDMI Monitor Cables NONE
Eyefinity / GeForce 3D Vision NONE
Keyboard & Mouse NONE
Mouse NONE
Gaming Mouse Pad NONE
Speakers NONE
Webcam NONE
Headsets NONE
Surge Protection NONE
Printer NONE
External Hard Drive NONE
Warranty 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour)
Home Installation NONE
Data Recovery NONE
Build Time Standard Build - Approximately 11 to 13 working days
Pricing Information
Price (excluding VAT) £430.00
Price £516.00
ASUS® A55BM-E FM2+ (M-ATX, DDR3, USB 2.0, 3Gb/s)
4GB KINGSTON DUAL-DDR3 1600MHz (1 x 4GB)
1st Hard Disk
STANDARD AMD CPU COOLER
Price: £429.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/amd-fm2-richland/e_WNFw3Bgx/
Outerarm
Thanks for the suggestions -- good starts to work from.
Taking keynes spec, I could swap the GFX card to a 2GB GEFORCE GTX 750 Ti and up the PSU to a 450w -- gets to £540. More cash than anticipated but I think that may give the performance I'm looking for... Thoughts?
Boozad
Don't get an APU if you're getting a dedicated GPU. The 750ti is a good shout, pair it up with a Bulldozer CPU.
Outerarm
Cheers mate! So for £509:
AMD FX-4300 Quad Core CPU (3.80GHz/4MB CACHE/AM3+)
ASUS® M5A97 LE R2.0 (DDR3, USB3.0, 6Gb/s)
2GB NVIDIA GEFORCE GTX 750 Ti - DVI, mHDMI, VGA - 3D Vision Ready
1st Hard Disk
Outerarm
Thanks again!
Right, looks like we may have two options, one AMD, one Intel:
AMD £515
Processor (CPU) AMD FX-4300 Quad Core CPU (3.80GHz/4MB CACHE/AM3+)
Motherboard ASUS® M5A97 LE R2.0 (DDR3, USB3.0, 6Gb/s)
Intel £520
Processor (CPU) Intel® Core™i3 Dual Core Processor i3-4330 (3.50GHz) 4MB Cache
Motherboard ASUS® H81M-PLUS: Micro-ATX, LG1150, USB 3.0, SATA 6GBs
The AMD option has capacity for more additional drives and GPUs than the Intel spec (albeit with improved PSU), but the Intel config draws less max wattage (264 vs 312). Checking reviews the Intel chip comes out on top with generally better performance in all cases (for example http://www.cpu-world.com/Compare/351/AMD_FX-Series_FX-4300_vs_Intel_Core_i3_i3-4330.html).
Based on this I'm edging towards the Intel option, but again, thoughts would be welcome on this!
The rest of the spec:
COOLERMASTER ELITE 311 BLUE CASE
1st Hard Disk
INTEL STANDARD CPU COOLER
DVD Recovery Media
Outerarm
Thanks again guys, +rep all round.
With the updated CPU (and an upgraded PSU as the checker tool now things the GPU needs it!), we have the following for £540:
AMD FX-6300 Six Core CPU (3.50GHz/8MB CACHE/AM3+)
1st Hard Disk
I will likely add Office Home & Student to this, but otherwise I think that may be it. Any further thoughts while I mull it over with SWMBO?
