Optimus VII hard drive location
Shane727
Hi, I'm looking to upgrade from my HDD to an SSHD but where would the hard drive be on the laptop. Is there a panel/slot i can open to find it or does the entire back panel need to be unscrewed? Thanks
You have to take the whole back panel off the laptop, be careful with the screws and make sure you use the right size screwdriver as the plus head gets worn down very easily. Once the back panel is off you can access the HDD (from here is different depending on which slot the hard-drive you want to replace is in).
