My Spec:
Optimus Series: 15.6" Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-4700MQ (2.40GHz) 6MB
8GB Samsung SODIMM DDR3 1600MHz (1 x 8GB)
NVIDIA® GeForce® GTX 765M - 2.0GB DDR5 Video RAM - DirectX® 11
Memory - Hard Disk
1TB SERIAL ATA II 2.5" HARD DRIVE WITH 8MB CACHE (5,400rpm)
Bluetooth & Wireless
WIRELESS INTEL® N135 802.11N (150Mbps) + BLUETOOTH
Optimus Series 8 Cell Lithium Ion Battery (5,200 mAh/76.96WH)
Power Lead & Adaptor
For a few months now my laptop has been struggling to turn on/ come out of sleep mode.
Generally it will power up, lights come on, and within about a second it is followed by a high pitched 'bip' and loses all power before even reaching the splash-screen, then after a few seconds it will automatically power up and try again.
Typically it fails to start at least once every time it's turned off/shut down/asleep, but this can happen stuck on a loop multiple times. Which means when it does boot it has to boot from scratch.
The only changes made to the above spec was an upgrade in RAM (to 16GB Corsair 2x8GB) a couple of years ago, and I have had no issues with that, and around a year ago the battery died all-together and holds no charge at all. But it does this regardless of RAM configuration and with+without the battery being in place.
Anyone have ideas what the problem is or how I can fix it? (if at all)
Bip noise is very quiet (might need to turn volume up, beware of background static noise) , but about 2-3 second in
[video=youtube_share;3RiCHW90FVA]https://youtu.be/3RiCHW90FVA[/video]
Memory - Hard Disk
