Optimus series portable review
rubjim
A great product that meets what I need, to be able to perform high quality work and graphic weight thanks to the great power of the laptop.
Also in games it has given great performance and good experience in this aspect.
The only criticisms I would say about this product is the lack of a manual for using the laptop, since although the vast majority of average users can configure a normal laptop, in this case it has several options for gaming, graphics and more aspects that could be collected in a user manual.
In conclusion, it is a product that offers you a lot of performance and hardware customization for a very good price.
PC49laptop
I have so far narrowed down a new laptop to an Optimus 17inch, can you help with a couple of questions? The keyboard, not too loud & clicky? The backlit function, what colour options & do the actual keys light up to see characters? Does seems a good compromise with weight, size, configuration options & coolability of the laptops
Deleted member 94250
I have the Optimus X 15.6".
Good keyboard, not too mushy and a gamer friend called it a good "fake mechanical" feel (its membarne. for a membrane to feel that way is apparently good, who knew?)
Yes the backlight highlights all keys and 2ndary functions.
AMAZING cooling despite being small at 15.6in, while gaming the max I get is usually 75ish C, and the majority is between 55-65. GPU between 50-65 usually.
Config options use the website.
View attachment 15270---- View attachment 15271----View attachment 15272
out of curiosity what specs did you get?
I have the 15.6in Optimus X with an i7 9750h, 2060, 16gb dual channel 2666mhz, and a 512gb m.2 SSD. I LOVE my laptop, it's light years ahead of my previous i3 5-something U which had 4gb of ddr3 and an HDD.
Only regret a gamer would have is the refresh rate, I got the 60Hz screen to fit the specs into my budget (I don't really game, I got a free RDR2 copy and that's all I've done, really.)
