Optimus PRO 15.6 - RGB Keybord control driver
GusBat
Hello, I bought my Optimus PRO without an OS because I already had a windows key. It came with the OS pre-installed and I authenticated. The issue is the driver to control the color of the keyboard lights is not installed and I can't find it online. Does anybody know where to find it?
You can’t use the test windows that’s on the laptop as it’s not properly configured and will cause issues. You’d need to clean install windows from scratch.
All your drivers are in your downloads section of the main PCS account, but you allow windows update to install all driver where possible, then just self install gaming center and nvidia.
