Edit: If you read my earlier post on here I've changed it!
I now know that I have a display problem with my Optimus IV. We went out last night and left it running, when I came back it was switched off. I noticed the mains power lead had pulled out of the power brick so I assumed it had shutdown because of a flat battery. But When I reconnected the power it wouldn't start. I left it on charge all night, the green "battery charged" light was on this morning but it still wouldn't start.
I've now discovered that Windows is booting, I can hear Skype start after logging in, so my problem is no display. The backlight is on but I get no splash screen on boot and no display of any kind.
As I said it failed whilst we were out so I've no idea how it failed. It's been as good as gold though, no hint of a problem. It's not been off the boat for weeks and has just be sitting on the cooler pad plugged in. I rarely close the lid so I doubt it's a damaged ribbon cable. I realy can't explain how the display could just fail like that.
Any suggestions of what to look for and where to look?
Edit: With the VGA cable plugged into the TV I can see the display on the TV and all works ok there but still no display on the laptop screen.
So what should I look for?
