EliseRobinson
(Wasn't sure if this should go in the Laptops section or check my spec section... but here goes!)
Hi all,
I'm just starting my degree in graphic design and often find myself running applications from CS4 together. My current laptop (Samsung R560) was brilliant but it's got a really dodgy charging port now and I can't let my student loan sit idly in the bank... My budget is £850 tops.
My main question: is this spec overkill for CS4 and WoW on pretty settings? What spec would save me some money while getting the right performance?
Optimus II: 15.6" Glossy Full HD LED Widescreen (1920x1080) - Are Matte screens good for designers? I've heard a lot of arguements about there being no such thing as "true" colours and matte screens can look dull - but are they much, much easier on the eye? I do use my laptop every day for at least a few hours but have never had eye strain or had difficulty with my glossy screen.
Intel® Core™i7 Quad Core Mobile Processor i7-2630QM (2.00GHz) 6MB Cache
8GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (2 x 4GB)
nVIDIA® GeForce® GT 555M - 2GB DDR3 Video RAM - DirectX® 11
Memory - Hard Disk
500GB WD SCORPIO BLACK WD5000BPKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm) - Would a SSD be a better investment?
= £799 with silver warranty
Thanks for all advice - in advance!
PS, just to add another spanner in the works: Optimus II or Macbook Pro (as it's the stereotypical "industry standard")? I can't justify the price difference...
Hi all,
Memory - Hard Disk
