ok - i got the Optimus 2 17.3" - its the 2GHZ i7quad version with 8GB samsung 1333MHZ ram. Ive loaded the 64bit windows 7 premium version onto it...
On my old desktop, - ive got the same OS (64bit) but its only got 2GB ram - also its 3ghz dual core. - when idle - it uses 950/2048mb RAM...
On my Optimus 2 - ive got the same applications as my old pc (but no junk files) BUT when idl its using 1.5/8gb RAM
Im putting it down to the drivers that came with the optimus... -
Can someone (a tech person) tell me wheat i can disable in startup (MSCONFIG) - so that my Optimus 2 will use less ram?
I know i cant disable hotkey because then graphics switching wont work, - like wise there are other drivers that will cause isues if i disable them - so expers advice would be nice haha
