Opinion on this build?
Bolter
CORSAIR 230T COMPACT GAMING CASE - RED LED
Intel® Core™i7 Quad Core Processor i7-6700 (3.4GHz) 8MB Cache
ASUS® Z170-E: ATX, LG1151, USB 3.1, SATA 6GBs
8GB HyperX FURY DDR4 2666MHz (2 x 4GB)
4GB AMD RADEON™ R9 380 - DVI, HDMI, DP - DX® 12, Eyefinity
1st Hard Disk
M.2 SSD Drive
128GB M.2 2280, SATA 6Gb/s (510MB/R, 310MB/W)
Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler
DVD Recovery Media
Frank100
Rising Star
What's your intended use and is this the top end of your budget?
Generally speaking for just high end gaming an i5 is fine. The i7 makes sense if you also want to do more processor intensive tasks.
The R9 380 will get very hot. I do like ATI cards particularly for doing co-processing work but they are harder to keep cool and use more power than the Nvidia cards. For gaming the GTX970 is the sweet spot and this will use a lot less power and stay much cooler than the ATI card you've suggested. I'm also a little uncertain how well a 450W PSU would cope long term with a higher end gaming card. Even with the more efficient GTX970 I would up it to 550W.
The processor has a built in memory controller for communicating with the RAM and it runs at 2133MHz by default. Unless you overclock this then it won't fully utilise the faster RAM. Even at the faster speed I don't know how much real world performance you'll see. That will save a few £s. Maybe instead get 16GB of 2133MHz speed? Again without knowing what you'll use it for it's difficult to say how much you'll need.
I think I need more info before knowing what else to suggest but hopefully the above will give you an idea.
Frank100
