Hello, I have recently encountered a problem with PC.
It's only letting me have one monitor work at a time when I have all three connected, but if I try switching them round they work fine? All suggestions appreciated thanks in advance
If I unplug two DVI cables I will get a signal on another monitor (I'm using three) and my cards are nvidia gtx580s in sli
Are you trying to set up Nvidia Surround or Extend.Hello, I have recently encountered a problem with PC.
For Extend you need to disable SLI.....
Yes,but not as one if that makes sense,good question really,but I believe it's the only way to extend 3 monitors with 2 580 Nvidia cards.Are you still using the power of both cards when you do this?
