Raders09
My PC rig was working fine then after a reboot it started to cut both sides of the screen, I can changed the resolution in Windows to stretch the screen but does not solve the problem. i updated the drivers still no luck, made a new install of windows still no luck.
I'm thinking it might be the DVI-HDMI cable I'm using possibly faulty? I have a VGA-HDMI but my TV seems to only show The screen on a DVI cable what do you think i should do?
[Motherboard]: M2N-E SLI
[CPU]: AMD Athlon(tm) 64 X2 Dual Core Processor 4600+ 2.4Ghz
[RAM]: 2x1Gb Kingston DDR3, 1x MEADR522P4701- PQI 2GB DDR2-667U
[Videocard]: x2 Nvidia GeForce 7600 GT [Setup]: SLI
[BIOS]: Phoenix - AwardBIOS v6.00PG [Version]: ACRSYS - 42302e31
[Operrating system]: Windows 7 Ultimate SP1 64 bit
