AleTax
Hi guys, so I had to do a clean install of windows cause I forgot to wipe 1 partition that came with PCS Windows test system and it was causing me some issues. Now when I boot up the PC, only 2 of my 4 RAM sticks turn on their RGB, after I get into desktop all 4 of them light up as soon as iCUE boots. What could it be? Just to clarify: all 4 sticks are detected as I can see in BIOS and in Windows
While clean installing, I managed to wipe all partitions again just in case, since as I said I was having some issues.
EDIT: sorted it out. The issue was lying in iCUE, which in RAM menu had “hardware lighting" set to all but it wasn't, so I clicked "all" again" and now it's ok. Hope this can be useful to someone else
Even tho I solved it, I find it still weird they didn’t all light up but only 2. I remember when I got the PC and clean installed it (forgetting - not noticing that one partition I left) they used to all light up even before I got iCUE installed. Maybe there is some other solution as well?
