Hi have a computer (4 years old this oct) that I bought from here.
Just after a bit of advice.
The computer no longer powers up when I press the on button.
There's a light on, on the motherboard (ASUS® P6X58D-E and the card reader light is on.
Pressing the on button does nothing (nothing spins up fans etc).
So I took the top of my case (CM HAf 922) to get to the switches but nothing seems loose etc.
I followed the power cable to the motherboard and unplugged it and plugged the reset cable in to the power to try and get the reset switch to become the power on (saw this on the web), but no joy.
Someone suggested using a screwdriver, touch the 2 powers pins should boot the machine, but also no joy.
The PSU is fairly new (corsair 650 module) replaced old one about 18 months ago after it went bang, so pretty sure that's fine.
I rarely use this computer, I have it hooked up to a 32" Tv in my computer room just to watch films. netflix etc.
I'm not going to spend much (if anything) to try and sort this.
So if there's nothing I can do I'll just salvage the hard drive, Graphics etc for spares.
Any advice would be appreciated.
On a side note if all's lost, the memory I have in the machine is 6GB CORSAIR XMS3 TRI-DDR3 1600MHz (3 X 2GB) and In my newer computer I have 8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB).
Would it be possible to add 2x2 of the corsair mem to the 8gb (2x4) computer to make 12gb or would this cause problems and instability?
Thanks for any help.
