Alright, I'll make it rather quick.
Since I had my new desktop from PCS, got everything installed and sorted, I noticed that system [Win7-Ult-x64] starts hogging more RAM than XP ever would, once uptime gets long enough.
One way to prevent comp from running out of memory would be to upgrade to 8GB utilizing RAM chips of identical or closest specs.
Problem is, PCS uses Samsung Semiconductor RAM which is impossible to obtain for an individual like myself. Thus, I was look at getting some 2x2GB kits from Crucial.com [currently on a budget so more expensive ones are rather out of the question] and the site was unable to identify most of the components [not a surprise as it's custom-built.
Anyway, RAM was identified as 2GB DDR3 PC10600 1333MHz 256Mx 64 240pin CL9 Samsung Chip [model ID: M378B5673EH1-CH9].
Now, would THIS kit be compatible with currently installed Samsung 2x2GB? I just want to avoid "lowest common denominator" effect and also, I won't bother with just single chip due to Dual Channel being used ONLY with 2 chips [otherwise the odd 3rd will not be detected at all].
Final thing: is it possible to order more identical RAM from PCS? If yes, how much does it cost, and, if not: is the above set from Crucial compatible with present memory settings?
