NZXT H511 Case replacement of 20 pin to front USB3.0 female connectors.
Ad745
I have a "NZXT H511 MID-TOWER GAMING CASE (WHITE)" purchased in 2020 and I have snagged and damaged the front USB ports.
I have taken out the damaged part and it is an (approx) 65cm dual cable. 20 pin to motherboard at one end and 2 separate female USB3.0 connectors (with purple colour code inside the connectors). The 2 female USB ends have screw holes for mounting on the board that positions itself at the top front of the case.
I have attached a photos of the cable. Does anyone know where I can get a replacement part?
Thank you from Adrian
Hiya, is this a PC specialist system? Could you post your full specs from the order page?
Ad745
Hi, yes purchased July 2020, I have attached the invoice which details the build.
