Nvidia GT 430
gavcor
Hi Guys
Anyone help on this as it slowly driving me mad. I had my new PC last week all is good apart from multiple issues with my Graphics card. I have the latest drivers installed however im unable to play blue ray movies and also im getting really low graphics resolutions available to my 1080p HD TV.
Any ideas what could be wrong ive been told to find vista drivers for the card as the windows 7 one dont work tidy. Anyone else come across this with any of the cards from here???
Post Should Read GT430 sorry!!!!!
Fear
As you have not put your specs i have got to ask did you order a blu ray drive, if so have you installed the cyberlink software from the cd ?
For the resolution right click on your desktop and select Nvidia Control Panel and set you resolution there it will show all the available resolutions your monitor can display.
gavcor
Hi Fear
Sorry about the delay mate yes all the cyberlink stuff was installed alongside the drivers. The Nvidia control panel now allows me to set my screen to 1080p after installing a number of drivers i found one which functions correctly. The display however is very bad when running at this. Just looking at the start button on the main OS screen shows various pixel issues the image looks more of a hexagon rather than a circle.
